Old 27-Mar-2006, 12:47   #1
keefer keefer is offline
keefer's Avatar
Can anyone make some shims please ?
ok I need two shims for my right hand footrest
as I have put a bigger exhaust on there and they don't fit at the mo
if anyone can help give me a shout and I will send the measurements on.
Thanks all.
K
Old 27-Mar-2006, 13:36   #2
RickyX RickyX is offline
RickyX's Avatar
If you can't get some nicely turned ally shims you could try either a thick stack of washers or a simple square/rectangular ally block of suitable thickness drilled to suit the mounting bolts.
RX
Old 27-Mar-2006, 13:47   #3
phil_h phil_h is offline
phil_h's Avatar
Stainless washers work a treat, as you dont get that problem with the plating on ordinary washers being 'slightly less than perfect'
Old 27-Mar-2006, 17:26   #4
keefer's Avatar
all sorted.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:53.
