Old 04-Apr-2006, 12:47   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Bleeding Clutch
I've just replaces my clutch with a Brembo radial M/C and the slave cylinder with one of a 996R (mines a 1999 996 bip).
I eventually got the clutch fluid though and have tightened everything up.
But now I cannot move the clutch lever, what have I done wrong?
Dave
Old 04-Apr-2006, 13:06   #2
Wrong size clutch push rod? There are two sizes depending on the slave cylinder type - of which there are more than one!
Sorry I can't be more specific, maybe Nelly can give you the exact details.
Old 04-Apr-2006, 13:21   #3
raykay748R raykay748R is offline
Bikes: 748R, ZXR 400
raykay748R's Avatar
Mood: Glad to be back down south.
As far as I know (which isn't much ) the pushrod diameter changed when the clutch slave changed.
If you look at the external face of the slave cylinder, if it's the new type instead of a flat face it will have a star shaped (TORX) insert. If you have this type then you should have changed the pushrod for the new type to match at same time.
The lever not moving at all would indicate a mechanical problem of some kind rather than hydraulic. Whip the cylinder off again and check that the pushrod is moving and that all is ok.
Good luck
Old 04-Apr-2006, 13:31   #4
dave996's Avatar
Mood: Fed up...
Yep I changed it from a flat face to a torx style one.
Old 04-Apr-2006, 13:34   #5
raykay748R's Avatar
Pushrod to suit it is then. Give the usual suspects a call they'll get one in or send one to you.
Old 04-Apr-2006, 13:38   #6
dave996's Avatar
Mood: Fed up...
Hmmm problem.....Even with the cylinder removed it still isn't budging
Any thoughts?
Old 04-Apr-2006, 13:43   #7
raykay748R's Avatar
Strip down clutch on other side, easy peasy, cover off, spring bolts undo, remove pressure plate, pushrod now accessable.
If you have to take clutch pack out (you shouldn't but who knows) make sure you keep them in exactly the same order as they came out. Tres importante!!
Pushrod locates in a small bearing within the pressure plate.
Old 04-Apr-2006, 13:47   #8
dave996's Avatar
Mood: Fed up...
But surely with the cylinder removed the lever should now move, this isn't happening.....I'm I being stupid here!!!
Old 04-Apr-2006, 13:50   #9
raykay748R's Avatar
Ah sorry sport I thought you meant the pushrod isn't budging. Different saga!!
Right, be careful of spillage here. If you back bleed the cylinder(push the internal piston within the clutch slave) back what happens?
The piston should make it's way inside the cylinder pushing fluid back up the line into the reservoir (remember spillage). Is piston seized??
Old 04-Apr-2006, 13:57   #10
Harv748 Harv748 is offline
Harv748's Avatar
Yep
Good luck
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:18.
