General Motorcycles only
Old 11-Apr-2006, 12:56   #1
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Floating disc bobbins
There's a bit too much play for my liking in a set of Brembo cast-iron floating discs I have. The feel at the lever just didn't feel right on a few occasions when I was out on the bike at the weekend.
Is it possible to source new bobbins and clips for them?
TIA.
Old 11-Apr-2006, 13:01   #2
Hiya,
I think these guys sell the kits seperately somewhere....
http://kaemna.de/cms_en/katalog.htm?...el&artikel=218
Frank
Old 11-Apr-2006, 13:02   #3
Cheers Frank. Will investigate.
Old 11-Apr-2006, 13:05   #4
Here we are:
http://kaemna.de/cms_en/katalog.htm?...el&artikel=217
Old 11-Apr-2006, 13:40   #5
TecMoto used to do a set of bobbins which replaced the standard ones and also turned your disks into fully floaters. I think they were STM ones at £67 a set (two disks).
Don't know if they still do them or have them in stock, but could be worth a ring?
Old 11-Apr-2006, 13:48   #6
Thanks Antoyne - these are full-floaters. Occasionally in a corner on the brakes I will get vibration from them which can be a bit unsettling. The 748 I have doesn't suffer this and it has the same discs. Braking in a straight line is mostly fine.
Old 11-Apr-2006, 13:53   #7
Oh yes, should have read it properly!
Old 11-Apr-2006, 14:46   #8
you can direct replacements from Brembo via GPR. Bobbins, shims and clips etc.
Old 11-Apr-2006, 17:45   #9
Thanks Nelly - I will order some tomorrow then.
Old 11-Apr-2006, 19:42   #10
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Not 100% sure why you'd need to replace the bobbins unless they where actually worn. Shouldn't affect brake feel (e.g. Pad knock off/back) unless something else is off. maybe wheel slighty off ballance too?!? You can also get wavy washers that settle them down.
rgds, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:48.
