Old 16-May-2006, 22:08   #1
900SL Pete 900SL Pete is offline
900SL Pete's Avatar
Tyre Pressures
I am sure that some one can give me the recommended tyre pressures for a 748 Bip. I've fitted a single seat so ride alone with no passenger and medium to fast riding.
I've checked the current presure and find the rear at 26psi and front at 15 psi, which I'm sure is not right?
Help appreciated before the weekend when I plan to ride out to Barmouth and through Snowdownia Sunday if the weathers good
Old 16-May-2006, 23:09   #2
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
IIRC 33F and 36R but wait for the experts to come along and confirm that.
Old 17-May-2006, 06:48   #3
Same here.
Chris.
Old 17-May-2006, 07:50   #4
900SL Pete's Avatar
Thanks Zed & Chris, I will pump them up then as we dont want any tumbles do we
The weather looks s*@t for the week end so looks like I'll have plenty of time to prepare.
Old 17-May-2006, 07:55   #5
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
I have the same bike as you, 748S with bp seat. I run 31F and 34R. Feels solid on roads for me.
Reduce to 30 all round for track.
Old 17-May-2006, 09:32   #6
weeksy2 weeksy2 is offline
anything you run HAS to be better than what you have....
It's all down to personal feel and how quickly you want the bike to be or how 'flighty' might be a better turn of phrase....
It can also depend on road conditions, weather and temperature.
Like said about anything over 31 is 'road' sort of pressures, up to and including 37-38 depending on preference.
It's generally a little lower on the front tyre pressure than the rear (on road approx 2-3psi and track 1-1.5psi)
Old 17-May-2006, 20:00   #7
Gaz 748's Avatar
32 - 34
Old 21-May-2006, 11:33   #8
Godders Godders is offline
Mood: Praying for a long dry 2005
I run 33F 35R for road, feels fine. I also run a 70 profile up front as opposed to OEM fitted 60, works for me.
Old 21-May-2006, 13:49   #9
CipiVTS CipiVTS is offline
CipiVTS's Avatar
I run 120/70 front 180/55 on my 916.
What pressures do you guys recommend on street and on track.
The pressures given here are measured with cold tyres or warm?
Regards
[Edited on 21-5-2006 by CipiVTS]
Old 21-May-2006, 14:31   #10
ath748's Avatar
Pressures always with cold tyres.
Read above for the answer!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:50.
