General Motorcycles only
Old 18-Aug-2006, 22:45   #1
Chief R.B. Chief R.B. is offline
Mood: looking to move in a new direction...
Cool Sticky Stuff...
Evenin'
I want to remove some of the decals on my ninja...
Does anyone have any tips for getting them off?, they're not laquered over but i could do something to help disolve the solvent.
Would thinners work or too harsh???
Fingers crossed its dry tomorrow, duc's going on a long thrash somewhere if not ninjas coming to pieces!
Thanks in advance
Ant
Old 18-Aug-2006, 22:48   #2
I usually use Brake cleaner or carb cleaner, can't rember which is the best out of the two for doing it.
Old 18-Aug-2006, 23:12   #3
jgriff jgriff is offline
jgriff's Avatar
Eucalipyus oil is the best stuff for removing any of that gummy sticky stuff. And it smells good too!
Old 19-Aug-2006, 08:28   #4
rcgbob44's Avatar
Heat them up with a hair drier then they just peel off!
Then you can clean the area up with a brillo pad and brake fluid!!!!!!!!!!
But a hair drier really does work.
Things of beauty: Ducati 998s Mono: BSA DBD34: Vincent Black Shadow: Manx Norton: 1983 Laverda Jota: Matchles G50: Me!
Old 19-Aug-2006, 12:46   #5
Thanks guys
Ooh...now where's my Nicky Clarke sweetie...
Old 19-Aug-2006, 13:21   #6
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
White spirit is a lot less harsh than brake cleaner. Softens the glue and allows you to clean it all off gentley.
Old 24-Aug-2006, 17:03   #7
Grib Grib is offline
Grib's Avatar
Mood: Ducati-less!
Bit of WD40 should fetch the sticky stuff off no probs
Old 24-Aug-2006, 19:06   #8
Hairdryer worked a treat but still got some really stuborn glue on from the tank pad i took off and i can't get anything to work...any ideas??
Thanks for the tips all
Ant
Old 24-Aug-2006, 19:55   #9
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
Have you tried Iso Propyl Alcohol available from any chemists, will remove most glue residue and oily marks, Benzine is the next step up but a bit more harsh than IPA.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:07.
