Old 10-Nov-2006, 12:09   #1
RCA
Clutch pressure plate removal
When I slide the pressure plate off, the push rod appears to be fixed to it and pulls out with it? Do I just need to tap it loose/free, so the pressure plate slides off, leaving the rod in place? Thought I would do the sensible thing and ask before I reach for the hammer...
Old 10-Nov-2006, 12:50   #2
moto748 moto748 is offline
That's normal. There's no problem about removing the plate and rod together.
If you need to separate them, you can do it 'off the bike', but normally there's no need.
Make sure the two O-rings on the rod aren't damaged, and clean, then lightly grease the rod before you put it back.
Old 10-Nov-2006, 13:18   #3
RCA
Understood, cheers.
Old 31-Jan-2007, 00:50   #4
RCA
How do I seperate the 2? I have a new clutch plate to fit.
Old 31-Jan-2007, 07:13   #5
You should just be able to pull the rod out of the bearing.They can be quite tight tho!
Old 31-Jan-2007, 14:59   #6
RCA
reet, will give it a good wipe tonight and get the rubber gloves on....oh er!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:16.
