General Motorcycles only
Old 11-Nov-2006, 16:12   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
What make of oil filter do you use?
Just a simple question really...............
Old 11-Nov-2006, 16:18   #2
K&N. Probably the most expensive but they have a good reputation, came out well in tests and have a drilled nut on the end which make them very easy to remove and lockwire on the race bike.
Old 11-Nov-2006, 16:23   #3
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Same ere.
DC
Old 11-Nov-2006, 16:37   #4
keefer keefer is offline
keefer's Avatar
I use Ducati ones from the dearer
where do you get the K&N items from then ?
Old 11-Nov-2006, 16:48   #5
I bought the first lot off ebay and then contacted the bloke direct when I needed more earlier this year.
They cost about £7 each so not cheap, but saves hassle of lockwiring with jubilee clips and stuff.
Old 11-Nov-2006, 18:20   #6
Founder Member
Paul James's Avatar
I use Ducati parts and change them regularly, if anyone gets a filter really stuck don't forget that I have made up a tool that locates in the base plate that always gets them shifted. Just need to tear off the outer can to get at the baseplate.
Members are welcome to borrow it for the cost of postage.
http://www.multirole-eng.com
Old 12-Nov-2006, 18:01   #7
DC DC is offline
DC's Avatar
Talking
I had that when changing a oil filter on the sps lump when I got it. Made up a tool that sounds very similar. Ended up removing the outer case and locating it in the holes that form the base of the cartridge.
Beats me how anyone can get a filter on that tight! must have fitted it without oiling the sealing ring first I guess? Freaking numpties.
DC
Old 13-Nov-2006, 09:28   #8
Founder Member
Paul James's Avatar
DC
The one I made up locates on the holes in the filter baseplate as well, the other end has a female half inch drive so you can give it some serious leverage if it is stubborn. I reckon the filters tend to tighten slightly during use and there isn't much exposed out the bottom of the cases to get hold of.
Old 14-Nov-2006, 10:04   #9
I bet you boys would like to get hold of some of these...
Old 23-Nov-2006, 20:25   #10
galaxy galaxy is offline
I bet that's a plain old Ducati filter with a Corse logo painted on it!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
