Old 11-Nov-2011, 19:02   #1
adjustable forks - which ones fit M620?
as title, can I fit any Ducati ones, eg 998, 916, 900ss
my guess is yes as long as 65mm spacing for brakes and same front wheel spindle but not sure about yokes etc
thanks
Old 11-Nov-2011, 19:05   #2
dunlop0_1's Avatar
Don't think yer allowed to change them. Any Ducati forks that fit into the standard 50mm yokes.
Old 11-Nov-2011, 19:08   #3
A you are - can have adjustable forks.
so anything except Ohlins?
Old 11-Nov-2011, 19:11   #4
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
You can fit any Ducati forks as long as they fit the standard (for your bike) yokes.
There is a little legal fiddle though.
Old 11-Nov-2011, 19:14   #5
sorry, I know I'm dim - I just ride em! - I'm looking at a set of 998 and ST2 forks - will they drop straight into my soon-to-be-mine 2002 M620?
Old 11-Nov-2011, 19:20   #6
Ducati uses two sizes of forks - 50mm diameter and 53mm diameter.
Yours will be 50mm diameter, as used on most Monsters, Supersports and the other "smaller" bikes.
The "large" bikes get the bigger forks - 916 line, 999 line, 848/1098/1198, etc.
So no, they won't fit!
Old 11-Nov-2011, 19:24   #7
ok thanks
must check the rules then and see if I can change the yokes too...I thought some were running 996 forks....
Old 11-Nov-2011, 19:27   #8
ok thanks
Its no Yoke Paul, std ones for the bike, or peeps would be fitting T9 ones etc.
Old 11-Nov-2011, 19:30   #9
wonder what size M1100S are, nice radial calipers on those
would ST2 fit?
Old 11-Nov-2011, 19:34   #10
Senna3 Senna3 is offline
Senna3's Avatar
Mood: ready to race
900ss or st ones will do just check lenth as some are longer than others i have st ones and are about 65mm longer just means they poke throuth the top yoke a bit more could be good if you wanted to put clipons ubove top yoke ideal for a bad back
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:31.
