Old 15-Nov-2011, 20:38   #1
Lightbulb carby SS tank on a 620 monster
will it fit? I know it would fit on the old 583 but wondered if it would on the new 620. If so any extra mods I need? Assume being fuel injected it will have pump extra anyway (external?)
thx
Old 15-Nov-2011, 20:48   #2
paynep's Avatar
Mood: Wet wet wet
Rattler used one on his bike and the steel tank M620 or SSie pump fits straight in.
HTH
Old 15-Nov-2011, 20:59   #3
Senna3 Senna3 is offline
Senna3's Avatar
Mood: ready to race
I fitted one a couple weeks ago on the one i sold just use the ss rear bracket as monster is very high ,need to make a couple of support brackets for front or ask dallas as he has a couple hes not using ,then make a fasterning devise to hold it down or very simple
Old 15-Nov-2011, 21:04   #4
thx chaps
Old 15-Nov-2011, 21:49   #5
Dallas ran one all last year and now has it for sale, although you would need to source a fuel pump and fuel pressure regulator complete with housing.
Old 15-Nov-2011, 22:25   #6
I have an SS tank in the garage, complete with pump, so just brackets. Was thinking about trying it out, see if it helps with being able to grip the tank better than monster tank and if I can now get lower enough behind the screen
Old 15-Nov-2011, 23:11   #7
Is that a high pressure fuel injection pump, probably not if its off a carby.
And you'll still need a fuel pressure regulator to stabalise the fuel pressure on the injectors, 3.0 Bar is standard
Old 16-Nov-2011, 09:09   #8
When I swapped over to a 620 engine from the 600, we converted the SS tank at the same time - I guess it's the same process more or less!
We found that a Triumph FI pump is exactly the same as the Ducati one, and that this also fitted in place of the standard carby pump. You just swap them out.
The pressure regulator is built into the throttle bodies, so this was not something we needed to worry about, but if you want one then again the Triumph one was the same 3bar as the Ducati ones.
There were a whole load of cheap Triumph FI pumps on ebay, and their setup includes pump, regulator and a fuel filter that is exactly the same as the Ducati one too!
eg:
http://www.ebay.co.uk/itm/TRIUMPH-SPRINT-RS-955i-51-reg-2002-PETROL-FUEL-PUMP-/330624658629?pt=UK_Motorcycle_Parts&hash=item4cfac 3ecc5
Old 16-Nov-2011, 09:16   #9
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
It's a pretty easy fit I did both the Rattler one & the Dallas one the pump is a strait swap you just alter the pipe work, rear mount fits, you just have to make up a front fixing.
Old 16-Nov-2011, 12:07   #10
Chaz makes it sound so easy.....
so I'd need a new pump too then, thx for the links.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:27.
