Old 20-Feb-2006, 13:03   #1
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Removing mirrors
Just about to send my 916 Bodywork off to HR racetech for a re spray.....
Only trouble.. how do the rear view mirror come off the nose cone.
They appear to have two pins that push through onto some sort of bracket....help......
Old 20-Feb-2006, 13:04   #2
Harv748 Harv748 is offline
Harv748's Avatar
Yep...and between those two pins is a screw...small allen key needed...size of which escapes me now, but undoo the screw then pull/twist the mirror off (pins pull out with the mirror).
2 second job.
[Edited on 20-2-2006 by Harv748]
Old 20-Feb-2006, 13:13   #3
dst1's Avatar
Thanks Harv.
Mine appears to be a Hex nut, Its amazing what you notice when you open your eyes, I must have been half asleep.
Any other funnys I may encounter with bodywork removal that you could kindly tell me about...?
Old 20-Feb-2006, 13:24   #4
Harv748's Avatar
Not really...straight forward.
Remove the two screws from underneath the nose cone, and off it comes.
Remove the 2 dezus from underneath the fairings, and then the 4 from each side and then just take it away.
As for the seat, lift it up, unclip the wiring loom at the join, remove the rubber 'pitail' from the 'top-hat' stoppers and then remove them.
Seat comes off.
Old 20-Feb-2006, 13:37   #5
Buy a Haynes manual
Old 20-Feb-2006, 13:41   #6
dst1's Avatar
I got a haynes manual but being thick I did not understand there terminology...sorry....
Old 20-Feb-2006, 13:45   #7
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
R U posting these up to Lincoln?
I've got a bottom left to send but I'm looking at giving it to Rob748b.
Give me a shout on me moblie and lets see if we can sort something out
u2u
Old 20-Feb-2006, 13:48   #8
dst1's Avatar
Yes I will be sending them via carrier, Dave wants them for March 4th
Old 20-Feb-2006, 13:58   #9
dave996's Avatar
Mood: Fed up...
If you can get your fairings to me today or tomorrow before 12 o'clock then I can get them to Dave by Friday...save you a packet in postage.
Old 20-Feb-2006, 16:01   #10
dst1's Avatar
Thats very kind of you Dave but I will not be ready by then.
My Wife has use of DHL so It wont cost me a thing.
Well other than the bi weekly leg over and a take away curry.......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:08.
