Old 06-Dec-2006, 10:24   #1
rich-racing.co.uk rich-racing.co.uk is offline
rich-racing.co.uk's Avatar
Mood: make poverty history - cheaper Dukes now!
best brake pads?
could do with some new brake pads for the bike, anybody got any suggestions?
the pads in it are performance friction. have had a bimble about on the road with them, and ideally would like a bit more bite. do they need some heat in them to work properly, or are they just past the sell by date?
Old 06-Dec-2006, 10:27   #2
Might have a slight glaze? Whip em out and sandpaper them, then try again.
Old 06-Dec-2006, 10:31   #3
Yeah they do need heat in them, they're race pads not for road use, but they give a consistent performance all the way to the end of their life.
They do need to be bedded in properly and there is a procedure to follow in order to do this. If you don't they won't give you the bite they're famous for and why a lot of people rave about them.
Old 06-Dec-2006, 11:56   #4
that's probably it - they would be cold, because the roads were damp.
if they're the weapon of choice, I'll probably get a spare set for gaudix
as they are a little low.
Old 06-Dec-2006, 12:03   #5
I love them, they're my pad of choice now
Old 06-Dec-2006, 12:33   #6
domski's Avatar
Rich, give Pete Sheppard a ring via his website www.fastbikesismy.biz he's the PF pad guru (and I did his website)
If you're feeling brave, mention me
They're not cheap, but do give more performance and value for money (as they last longer)
Personally I use Lucas pads (yes, I said LUCAS!!) - coz Louigi supplies them, but actually they turned out to be bloody good too. Speak to Rich @ Louigi Moto for those
Old 06-Dec-2006, 13:08   #7
thanks dom.
I thought the pads had gone off, but if they need heat to work thats probably the reason.
there's still some meat on them, so will probably try and fudge it until after spain (whoopee...............................!)
bound to be somebody with a spare set there if a problem.
Old 06-Dec-2006, 14:25   #8
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
Myself and Tim both run Bendix MF pads ......
Brilliant pads..never had any problems..loads of feel and super grip...and a little more cost effective than " others ".........
warm up instantly...and i have never had any fade.
hth
Phil
Old 06-Dec-2006, 19:32   #9
jhsracing jhsracing is offline
pads
Try the race pads from Brembo, these we have found to be the best for the application.
jh
www.jhsracing.co.uk
Old 06-Dec-2006, 20:10   #10
Got a couple of odd experiences with performance friction pads.
My bike - had a new set put in at Assen and a previously on/off brake lever became squidgy and horrible, many frustrated bleeds later and litres of brake fluid - no better.
Dessie - on the other hand -single disc - no issues whatsoever and they are still in the bike now which my son uses on the road and has no problems right from cold.
I put EBC ones in Max - hey presto - great feel again, on/off lever, no problems.
I dunno
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:55.
